- Location
- United States
3.0L V6 4x4
Automatic
A/C works, Heat works
118k miles
Class 3 hitch/receiver/ball, ready for a brake controller and tail light converter for easy towing
15-17mpg
Tru-Cool aftermarket trans cooler
Airlift 1000 bags in the rear springs
Cylinder heads surfaced, fresh valve job, all new brass valve guides, valve seals, Head work done by C&S performance in Butler, WI. $400+ in head work
New Toyota OEM parts from the head gaskets up. Including all new drive belts, water pump, front main seal, timing belt, misc gaskets, etc. $500+ in Toyota parts.
Brand new brake lines from the master cyl to the rear axle
New Rear axle/hub seals
Brand new rear tailgate, professionally painted
"Bad"
Front rotors will need to be replaced. Brakes don't grind, but they shake when braking hard.
$2500
www.lilevo.com/sell/4runner/new
Automatic
118k miles
15-17mpg
"Bad"
$2500
