Its time for the 4Runner to move on and a new project take its place.
1989 4Runner / 5 speed / 22RE / Asking $3700 all reasonable offers considered
Blue Metallic paint / Black rear top
Lots of upgrades
Approx 2 in lift ?/ body stock
Owner maintained - records
List of upgrades
Front Suspension / Drivetrain
Randy's R&P / Yukon front differential (open) ? 4.56 gears
Standard Bilstein shocks
Sway-A-Way torsion bars
Front half-shafts rebuilt and converted to quick change (i.e. no studs / grade 8 bolts)
Rear Suspension / Drivetrain
Randy's R&P / Yukon rear differential w/ Detroit Locker? 4.56 gears
Bilstein 5150 shocks
Old Man Emu Dakar springs
Remote breather
(both diffs and u-joints 3years/70,000 miles)
Axle cleaned / new seals / bearings / brake shoes when differentials installed (all Toyota parts)
Transmission / rebuilt by Marlin Crawler w/ HD bearing upgrade
Transfer Case / rebuilt by Marlin Crawler (stock gearing)
Marlin HD Clutch (1600 lbs / same as V-6 version)
(95,000 miles on tranny / t-case / clutch)
Budbuilt crossmember / skidplate (high clearance)
Poly body bushings
Engine / original / 490,000 miles
No smoke (no joke / unless you let it idle for 10 minutes or more / will cruise at 70 - 75 all day long / loaded)
Easily passes emissions (Chattanooga)
No oil leaks / fresh oil / new radiator / water pump / hoses / belts
Downey / K&N Intake
Downey Header
Flex-a-lite electric fan
Downey / Denso HD Alternator (new brushes / diode / regulator 2 years ago)
Duralast battery / about 2 year old
Brake fluid / PS fluid changed / flushed regularly
Brakes very strong and smooth / good pads
2 Sets of wheels and tires
15x7 in. black steel wheels by AR
BFG 31x10.5 AT's / lots of tread left
2nd set of black steel wheels
34x10.50 Super Swamper LTBs also lots of tread left
Poly body bushings
Trailer hitch receiver (2 in.) with light hook-ups
30x10.5 BFG AT spare
Interior in excellent shape
Corbeau seats (driver's side recently reupholstered / have kit for passenger side)
Rear seat belts upgraded to shoulder from lap belts
Black rubber floor mats / vinyl carpet / easy to clean-up
Awesome stereo / Sony CD / Infinity front speakers / Boston rear / JL Sub / 40 watt rms stereo Kenwood amp / Sony 100 watt rms mono sub amp
Back windows have light tinting
Hella 55w driving lights
I have owed this truck for the last year and it has never left me stranded. If you are looking for a cheap and reliable vehicle to get out in the woods with, this is your truck.
PM me for more details...
Edit: I also have both the front and rear factory third members with 4.10s in them.
Lots of upgrades
List of upgrades
Remote breather
Poly body bushings
Downey / K&N Intake
Downey Header
Poly body bushings
