Hello. I have a 1963 Dodge M37 that I wish to sell with 16812 miles. It has a very straight body without any rust through anywhere. The engine (230 cid) runs very smooth with good power and no smoke and does not use oil. The transmission (6.68 first gear), transfer (1.96) and 4 wheel drive (5.89 pinions) works great. The winch (8000 lbs. pto driven)works fine. All of the gauges work except the gas (the sender in the tank is bad). All of the lights work including the turn signals( needs two bulbs replaced). the brakes stop the truck well and does not pull at all. The truck drives well on the street (actually better than my 72 Land Cruiser). The tires are in good condition. Batteries are good and the charging system works fine (still 24 volt with water proof ignition). The seat cover is in great shape without any holes or tears. All glass in good except the drivers windshield has a crack. The windows roll up and down great. The doors close tight and the door lock hardware is tight. It comes with the hard top (with sliding rear window) and hardware for the soft top, as well as hardware for troop seats and jerry can and mount, extra water pump and starter.
All this truck needs for a very dependable daily driver is seals in the transfer and pinions, gas tank sender and I would replace the fuel pump as I have noticed it is damp.
The truck is in Durham,NC and the price is $3750
pics http://community.webshots.com/user/crossbones04
call for more info 919 698 6613
