Hi folks, I was adjusting the AHC sensors and checking out the torsion bar adjustment this weekend and did some measuring on the front suspension. Was wondering if anyone has measurements that might help me as a reference point.
With the AHC system, with the front at full droop on the jack, I am at 32" flat from the bottom of the rim up across the middle of the wheel to the fender lip, on a 16" rim. At ride height sitting down I measure 29.25".
I am doing some searching, but wondered what those of you who have OME or long shocks are seeing droop wise. I read in the AHC sensor adjustment thread that the right height for the front is 30.3" at ride height, allowing 2.75" of droop. I'm not a mathematician, but I think that means you are seeing 33" measured at full droop with longer shocks.
Do i sound like I'm in the ballpark?
Also do you think my droop is limited by the shock, or does adding a diff drop give you more droop as well?
Thanks for any input.
