After a few days, I finally got the 80 squared away on some maintenance I wanted to tackle. Valve cover, spark plugs & tube seals ( no plug wires, I'll get those later), new cap and rotor, distributor o ring, throttle body ( semi cleaned out; I wanted to address the upper intake manifold but ran out of time ) gasket, thermostat, rear heater lines ( over the valve cover) and phh ; ifzfephh.com silicone setup, radiator upper and lower hoses along with the thermostat hose, coolant flush and oil change ... Oh yea, fuel filter, whew! I also adjusted the timing.
So I'm moving onto the title of this thread, anyone have some pointers / suggestions before I dive in? I'm addressing the front knuckles/seals/bearing and rear seals along with a repacking of the bearings. Throwing on some brake pads all around and bleeding the dang rig. Hoping to get done with it all by Wednesday ( I take my time and play with my kids
). If you think you're faster than me, come on by and show me, I have all the tools and parts
. j/k
I was thinking of switching the birf's to opposite sides, or leave 'em in their current side and just service/repack them; any thoughts input to that idea? Also, I'm using mineral spirits as my parts cleaner, someone know of a better product at a major hardware store that's readily available? If not, I'll stick to the wire brush, rinse and scrub technique.
Thanks Steve for the hub socket, it's gonna work out. To everyone else who has input, Thanks in advance Fellas!
