Front E-Locker 80 series in LJ-70 Front Diff LJ-70... if possible???????
Switzerland
if possible??????? :rolleyes::whoops::confused::confused:
I bought an Front E-locker of 80 series, my front diff shafts (LJ-70) work with the Front E-Locker 80series diff??? :confused: :rolleyes:
I`m waiting your help :doh::doh::doh:
Hi All:
Yes, the 8 inch high-pinion front e-locker from a 80 Series will fit (with modification) into the front axle housing of a LJ Series Land Cruiser. A buddy has fitted one in his LJ73.
Regards,
Alan
If the 80 series front diff 8" high pinion and the 70 series front diff also 8" high pinion.....should be a straight install???
If its anything like fitting an e-locker into a std diff for the rear its do able...
But you need to get out the grinder and welder to modify the diff housing to accept the e locker.
And also tap in some new holes.... for some loooong studs.
I have done it for the rear.
