Front drive shaftproblem
Denver, CO.
I am having problem when I try to grease the front drive shaft, I can't fit the grease gun on there, the one at the very front works fine, but on the side that connect to the diff. won't fit, and I have try it from the buttom, side and from the top, couldn't get the grease gun fit on it.
Does anyone have the same problem? is there any tools do I need for it?
Thank you
I had the same thing with my grease gun as well. What I did was to take a grinder and carefully grind off a little bit of material all around the end of the gun and then it fit. It seems that the ends of some grease guns are a little larger than others and it is a tight fit when greasing the drive shafts.
