Hey Y’all,
i got the icon stage 2 lift installed about a month and a half back. I’ve sworn the truck sat higher on the driver side, and finally got around to measuring it today. I don’t really understand my results.
drivers side center of hub to fender: 23”
drivers side preload: 1.378” (3.5cm)
passenger side center of hub to fender: 22”
Passenger side preload: 1.378” (3.5cm)
this is with a completely full tank of gas on level ground with an empty truck.
I’m not super knowledgeable on suspension, but I would assume that the hub to fender measurements should be the same with the same preload, yeah? Or at least that the driver side should be the side sitting lower due to the extra weight?
is this something I need to adjust / fix?
