- Thread starter
- #21
No, I was not aware it is adjustable. I'll check that too.Did you adjust the vacuum booster pushrod length while you had the master cyl off?
Check the adjustment rod behind the master cylinder that goes into the booster. If it’s touching it will be applying pressure even without pushing the pedal. I had same issue this spring.
Thanks, I misread that before. I was assuming he meant the rod at the pedal. I have a new master on the way and I'll get the booster rod checked too.From earlier replies in this thread:
If there's not the tiniest bit of slack in it per the spec in the factory service manual, it can apply constant pressure to the master cyl and make your brakes drag.
