Adelaide is currently in project mode. I figured that as long as I am avoiding emissions work
, I might as well shape up the front end a little. Having spent some quality time staring at the front axle while wrestling TREs, I decided to rebuild the brake calipers, Now let me quash the hijack that is coming:
-yes, I know that 1995 4Runner calipers offer vastly improved braking while still being a bolt-on, and only require minor fab on the dust shield. I also know that combined with a master out of a T100, this is apparently the slickest system to hit braking since hydraulics. Not gonna do it.
-and yes, I know that it's probably cheaper to buy a junker set of 4Runner calipers and rebuild THEM than it is to rebuild stockers. No, I am not a starving college student. I am a starving Firefighter-EMT, thank you. I also am a rank rookie mechanic and am trying to learn by doing. Time consuming? Yes. But I have no deadline for the truck since I have another DD. Like I said, project mode.
So, my first problem is that one caliper has a stuck piston. The three others pop right out with compressed air, but not so our little friend on the lower inside. Shall I WD-40/PB/Mystery Oil? Is that safe for brake parts? Can I give a little taperoo with a brass or even a rawhide hammer without destroying the sides of the piston?
Second, I have a rebuild kit from Specter that contains boots and wires to go around, as well as similarly-sized square (in x-section) o-rings. I must have missed this in the tear-down: where does the o-ring go?
Third, why paint calipers? Everything else on the bottom half of this 60 shows serious cancer, but not the brake calipers. Why bother?
Thanks in advance!
Thanks in advance!
