Blew up a birf so I ordered a set of the Trail Gear Dirty 30 chromolly front axle shafts and birfs which are essentially the same as the Longfields with respect to dimensions, length, etc.
My front axle is a '77 that I have installed an Aussie locker, minitruck knuckles, and 4.88 gears.
My problem is when I went to install the chromolly birfs, after grinding the knuckle to make the birfs fit properly, I installed the inner axle shaft and birf but the inner axle shaft did not spline into the differential. Then I compared the chromolly axle shaft length to the stock axle shaft and noticed the stockers were longer. I now know that 76-78 axles had longer shafts.
Am I correct in assuming that I have to find a 79 or newer front axle to swap over my center diff, and hi steer arms over to in order to use my new chromolly birfs and shafts??
I can get my hands on an 83 front axle but I just wanted to make sure before I start to tear everything down. I have SOA so there is gonna be a bit of work involved to change everything over.
Maybe I have another option in order to use my chromolly gear? I had hoped to use the stock inner axle shafts with my new birfs but or course the splines are different.
