Fridge slide & third row seat
Colorado
Seeking some information from the users of fridge slides and third row seats. I'm in the process of planning a new fridge slide that will allow for a 63 quart edgestar, 500lb slides, and use one of my third row seats.
My current setup is 20" wide and has some room to spare on clearance for the third row seat to drop down. I figure the widest I can go is 20.75" (maybe a quarter inch more but seat might rub). The arb 63/80 slide is 21" wide, is anyone using that slide and able to get the third row seat down? Just want a sanity check before I order the custom pan for the fridge.
When it's built and installed, I'll share measurements for anyone wanting to do the same.
You should be fine. The ARB 63 slide is indeed 21" wide, measured at the mounts. It is hour-glass shaped and so you can cheat over the wheel well arch some.
I looks like a little more clearance (1/4") can be made by removing the plastic trim for the third row seat anchor.
