There's actually quite alot you can do to your 62 to improve performance without spending money. Start by advancing the distributor as far as you can w/out pinging under load. (loosen distributor, turn counterclockwise to highest idle, tighten, test drive, repeat w/turn back clockwise if necessary until you hear no pinging under load). Then, adjust your throttle and auto tranny kickdown cables at the throttle body...there should be minimal if any slack at idle. Yo want to back the cable body away from the throttle body until the rpm starts to rise...then reverse slightly and tighten. Same with the auto tranny kickdown cable. Take all the slack out of it. 62's don't do very well w/a taller tire...so forget about 33,32, and even 31 if you tow or live in the mountains. Everybody will bitch about this and say their 62 with 33's will pull mountain passes in overdrive at 70. Make em prove it, and bet lots of money, it's bull****! Join the 3FE list on yahoo, and save your header money, all the minor mods above will make more difference than the best headers ever made. And, don't forget a real tune=up.
