Freebies for South FL Mudders
Jupiter, FL
I've got some tools and other stuff that I don't have room for anymore, I was going to put this stuff on Craig's List but just don't want to deal with the hassle, I thought I'd post the stuff here and make it free to a good home in the Mud community.
The only caveat is I'd need it all to be picked up (North Palm Beach) on Saturday 7/20,because I am cleaning out a storage unit.
Tools
Porta-Spot, panel/spot welder- great 220 volt welder that I have done tons of panel welding with. This is the type of spot welder with 2 10' electrode leads so you can get behind a panel or underneath. The trigger stopped working and needs repair, transformer is tested perfect.
HF Table top/workbench - Sand/Media blaster cabinet - works fine.
HF 40lb Pressurized abrasive blaster, the tank type on wheels- works fine.
HF 20 Gallon Parts Washer with pump - works fine.
36" x 36" Steel Welding table on casters.
Large Work Table (I don't know the dimensions, 32" x 48" ?) on casters, has a formica top and bottom shelf, I use it as a workbench, it can easily be converted to a welding table with a piece of 1/4' plate.
HF 1 Ton Engine Lift (Foldable) - works fine.
Other
Smittybuilt FJ40 Front Double Tube Bumper with Winch Hoop - Like new.
Smittybuilt FJ40 Rear Double Tube Bumper with receiver hitch- Like new.
PM me if you want any or all of this, like I said above, it will need to be picked up in North Palm Beach next Saturday.
