- Vehicle Model
- Prado 150
- Location
- Frederick, Maryland 21701 United States
Classic Off Road Bumper for Toyota Prado 150 - $300
Comes with integrated driving lights and fog lights, transfer plate and winch mount capable frame mount
Specs:
Local pickup only at 8435 Progress Drive Unit BB Frederick Maryland 21701
Specs:
- A-frame Triple hoop to accommodate a wide range of lighting options
- Recessed fog light pockets come standard with Ironman 4x4 halogen lights
- ADR 69, 73 approved (Full Frontal and Offset Impact Occupant Protection)
- Tested to the highest standards of compliance with Australian Design Regulation,
- Airbag tested and compatible
- Two-part design with direct mount of winch cradle to chassis provides ultimate strength for bold recovery situations
- Winch accessibility with clutch handle access with line spool visibility
- Oil and pickled rolled steel
- Ultra-durable AKZO NOBEL Black Power Coat and pre-treated steel for rust resistance
- 360° Robotic welding for consistence and precise welds resulting in peak quality and unequaled strength
- UV stabilized polyurethane bumper over-riders reduce wear while providing light shock absorption from soft impacts
- Deep Hi-lift Jack points reinforced into bumper eliminating the need for high lift hooks
- LED Parking and Turn signal lights included and can be wired in conjunction with factory
- Increase approach angle enhancement gives you maximum use of every inch of your suspension
- 119LBS of additional vehicle weight after removing OEM parts and installing the Ironman 4x4 Bumper
- Integrated welded antenna mounting point for aerial antenna
- Mounting provision for LED driving lights and light bars
