Frame material question (1 Viewer)
Kodiak, Alaska
All you custom trailer/frame builders, got a question for ya.
I'm going to be building a trailer for light duty (2-track, dirt roads, etc) hauling of camping gear. Looking at 4' wide and 5' long and 3500# leaf spring axle.
I'm looking at using 2"x2", 3/16" (.1875) wall square steel for everything except for the vertical box, which will be 1"x1" square steel.
Does that sound stout enough for basic road hauling and some light off-road use? I'll be running no larger than 32" tires on 16" rims on it (to match the JK).
Thanks!
Andy
haven't built a trailer-yet, but I'd think the 3/16 wall 2X2 ought to be enough for a light duty trailer. Weight would be more of a factor for figuring dimension of your material. How much total weight do you expect to load it up with?
Use 2x3 for the main rails and critical parts. Use 2x2 for the crossbars if you want.
Don't skimp on strength.
