Wanted Flywheel for 87 60 etc. and 88 62 gas line (GA)
NE GA
I am installing a 4 speed into my 88 62 and need a flywheel, bolts and the pressure plate bolts and other misc parts for the conversion.
I also learned the hard way to not trust a junk yard pulling fool, I need the hard gas line that goes behind the head on an 88 fj62. It was not removed and got twisted when we pulled the motor.
Might have the line, got a picture of what you need?
Flywheel bolts and pressure plate bolts can still be purchased new from Yota. I recommend going that route. I have an extra flywheel. It needs to be resurfaced. Shipping will be a bear as it is heavy.
I’ve shipped 3 flywheels and they have all been $30-40 to ship, hope that info helps.
UPS. Double wrap in cardboard to protect teeth and your good.
I just bought a 62 that came with extra parts, let me get thru those and see if I still need the hard line . It goes between the soft line that comes off the filter, goes around behind the head, on the passenger side and has a banjo fitting to the fuel rail.
What do you want for the flywheel? Do you maybe have the bolts ?
$40 plus shipping. I do have the bolts I think. Just need to make sure I get you the correct ones. I did three clutch changes on a 40, 60 and Tacoma around the same time.
I'll message you later today. Please figure shipping to 30520 residential.
the 62 series and 80 series 3fe line have different bends. the ends are in the same place. only difference is where the clamps bolt to hold the line in place.
Is the clamp soldered to the tube?
I'm working on a 62 and rig I bought is a 62
I'll look tonight, I don't think they are solidly mounted. I was thinking they have a rubber grommet type clamp. so they will move, it's just the bends are different.
clamps are movable, the upper clamp on the 62 has a nut welded to the clamp. the 80 does not have a nut on it.
here's some pics for reference
2nd pic is the 62 series
last pic is the 80 series
