Flare mounting hardware
CharlieS
GOLD Star
I did a search and came up with a list, but am wondering if the flare mounting varied by generation (I think there are three or more different flare styles over the years?).
I have to get a state inspection this month and my 12.5x35 with 1" spacers are outside the fenders by a lot, which I am pretty sure will prevent me from passing the inspection.
I think I have cobbled together the right combination of flare pieces to cover all the wheel wells, but now I need to mount them.
This is for a 1994 80 series Land Cruiser.
For each side in the front:
  • 90467-09077 - 1 - Fender Flare Clip
  • 90249-06132 - 1 - Fender Flare and Mudguard Clip
  • 53858-60050 - 4 - Fender Flare Bolt
  • 90179-06144 - 4 - Fender Flare Nut
  • 90183-06016 - 2 - Fender Flare Nut Clip
  • 90159-60551 - 2 - Tapping Screw With Washer
  • 90189-06005 - 1 - Screw Grommet
  • 90189-05027 - 1 - Front Fender Flare Screw Grommet
For each side in the rear - door portion:
  • 61788-60011 - 1 - Rear Wheel Well to Body Molding Pad
  • 90249-06132 - 2 - Fender Flare and Mudguard Clip
  • 90179-06157 - 1 - Side Body Molding Nut
  • 90119-06595 - 1 - Bolt With Washer
  • 90467-09179 - 2 - Wheel Flare Clip
For each side in the rear - quarterpanel portion:
  • 53855-60010 - 1 - Front Wheel Opening Pad
  • 53858-60050 - 2 - Fender Flare Bolt
  • 90249-06160 - 1 - Fender Flare Pin
  • 61787-60011 - 1 - Spacer for Rear Running Board End Cap
  • 90179-06144 - 2 - Fender Flare Nut
  • 90159-60182 - 1 - Tapping Screw With Washer
I need them asap, so Amayama and Partsouq aren't going to work. Who are the current go to vendors for stuff like this? My local Toyota dealer?
I prefer the no flare look, but I need to pass inspection to be able to drive legally.
Alternatively, has anyone come up with different mounting options?
Thanks!
Order now and partsouq will have them to you about this time next week via DHL. Is that quick enough?
I've done 3 orders with them in the past six weeks and that's been pretty consistent.
Also put you VIN in and they will show the parts diagram for your truck. Yes, there were minor differences in the 80 series with flares and the LX 450 was rather more special,
Not all the bits and pieces are available without finding some substitutions i believe.
There a US vendor who sells kits of the flare hardware for front and rear flares.
Can't remember the name of the vendor, but a search might turn it up.
Got anyone near you you can swap wheels with to get it through an inspection?
Good ideas. Thank you! I like the way you think.
Old thread, but cruiser parts sells a new “kit” and was easy to order and quick to receive.
