im redoing the trailer wiring that was previously set up by the PO. he used side to side stab connectors and i want to solder it well to have the best connection. a couple questions i have are as follows. i'm doing a seven wire connector as i want to have power, back up lights and trailer brakes.
is the trucks wiring harness up to the job of the extra draw a trailer system would put in it or should i use relays? i think it likely is but thought i should ask. (just for the standard 4 wires. ill build the rest of the harness to the other 3 wires later)
for the standard 4 wires (brake/tail, right signal, left signal and ground) can i just splice into the trucks harness? being as they all have different bulbs and circuits i shouldn't need a brake converter box that is needed for those with tail/signal coming off the same bulb/circuit right?
cheers
cheers
