So I have been remiss in posting up here.
The 62 decided to give up the Connecting Rod bearing on #6 back in December. I was more than slightly peeved at myself as The oil level being inadequate was the likely cause.
So I parked it and waited till First part of this month to deal with it. 5 hours of pulling down the oil pan later the #6 bearing was completely destroyed, no visible damage on the crank shaft though so new bearings were ordered. After replacing the connecting rod bearings with standard size and putting it all back together, it made it about 50 miles before the knock was back.
So now it sits in my yard.
I guess looking for advice, the 3FE crank is available used for around 300. I can pull the motor and have mine machined but by whom?
The real bitch of it is that I only needed to make it till next february and it will have its final E-Check and then time for a SBC.
Dave
Dave
