FJ60 tire question
Northern Virginia
i have an 87' FJ60, with OME springs and 33 TSL's, when im at full flex they rub pretty bad.. what do you think i should do, body lift or trim the fenders with a sawsall
thanks
mark
if ya got rust trim the fenders and fix the rust or if ya dont get a 1 inch body lift from what i hear ya cant tell that ya even have it..
Are you talking about the rear fenders? What's your wheel backspacing?
I have the same problem, but with the 2.5 BDS lift. Rubs a little on the front fenders at full compression and real bad in the rear. I'm probably going to go with a 1" body lift or maybe a longer shackle, not sure yet. Also, with wide tires, mine 12.5", 3.5" bs on 8" wheels is to much. Next time I'm going to a 3" or even a 2.5" bs. Especially since I'll be going to a 10" rim and maybe a wider tire too.
I don't think you can avoid the rub front or rear with 33x12.5's on a 60. If you soa there will be no more rubbing.
If you use a 1" body lift where do you get the new mounts?
devo
[quote author=devo link=board=1;threadid=15298;start=msg144835#msg144835 date=1082864698]
devo
[/quote]
Custom body lifts:
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
there 33x12.50-15/10 with 3 5/8 backspacing (close), but it only rubs on the front.. with the OME lift the back it lifted more than the front. i think it's 2.5'' in the front and 3 in the back.. but if im reallllly flexing they rub on the back too.
-mark
