Wanted FJ60 Manual (39 Viewers)
Re: One piece OEM tail gate
Hey mark if you get that OEM rear tailgate, think i could nab your SOR tailgate? I need something to fill the void in the rear when i have the top off.
hey,
there are a couple sor tailgates on ebay, if you get that desperate.
jonathan
Re: misc. needed
thanks, I have doors, don't need whole front window assembly but would be interested in the two ww motors. Haven't decided about the seats yet, wife wants rear bench instead of jump seats. Let me know on those motors though.
I'm fine for now, i run a hardtop and ambulance doors during the fall, winter and spring. Would like to have something during the summer or when i take the top off for wheeling.
pto pillowblock for 78 or earlier
Subject lines sez it all. Got the driveshafts I need, just no pillowblock and bearing. I would take a whole/part driveshaft to get the pillowblock...Thanks Alan
Disc Brakes and 1000000 dollars
If anyone has disc brakes that I could swap into my 73 axles I need em(I think its 76 or later ???).  I am also looking for a good drivers side door.  I am mostly hoping for someone that is not to far of a drive from Alamosa CO.
Thanks
Ledge
We here in Pakistan are working on this project... Here is the link..
http://www.islamabadjeeps.com/work/tailgate/
Re: FJ40 heater fan and motor
I have all my heater parts out of my '70 FJ40 (working). Are you still looking for parts?
Re: Need Brake Master Cylinder
i have a whole bunch of em but i need to know which one you need,is it a double reservoir or single.
cheap too
ill send it wiith the floor mount 3spd stuff
shawn
Rear Swing Out Doors - Wanted
Need left and right swing out rear doors to fit my 1971 FJ40. Need doors in good shape, some surface rust is acceptable.
I have all the hardware but will consider package deal if price is reasonable.
Located in Auburn AL.
Thanks
Neill B.
Re: Brakes and a door
I have a door off a '63, in fact I have a pair. They both have the glass and handles, would need inside door panel, other than that perfect. I am in Montana, but have a friend that drives to the colorado/wyoming border every other week. Could send it through him, get it closer or could ship, I get a corporate rate, so it is cheaper. Let me know, you can have it cheap. Make an offer.
Thanks for the reply. I think I have found a pair that is closer already though. If you have a post 76 front axle I could still use on of those though. I hope you can find someone who will buy them. Ledge
Need 68-74 wiper motor / pivot pads
Does anyone have wiper pivot pads available? These are the rubber pieces that go between the wiper motor / wiper pivot and the metal windshield frame. It's the part labelled "4" in Specter's picture near the left top corner:
I need both sides, the motor side and the pivot side. If you have one or both in good condition, please email me: dtay@attbi.com. Thanks,
Dave
2F/F distributor gear needed
I'm looking for the gear off of a 2F/F distributor. I think they are the same if not I guess I really need a 2F gear.
Thanks!
Webster
76 FJ40 tranny hump
looking for one of these mine has some rust problems , any body have one they want to part with , im in Seattle , thanks Robb tmbrtmr@aol.com
selectro locking hub cam plate needed
Ya know, the circular ramped piece that helps the hub engage and disengage? Got one, ping me direct please:) Thanks, Alan
Re: Don't Laugh - FJ25 Parts Wanted
Jim,
I think I sold you a set of cutlass-type hubs awhile back. I have both the rotary style wiper and headlight switches. The light switch is currently in my cruiser, but I'm going to change that to the later pull switch. It is mounted right above the rotary switch, but not wired up yet. If you're running a vacuum wiper you sure won't need the wiper switch. Email me offline if you are interested. Aun2th@aol.com
Good Luck, in any case!
Ed Long
