Wanted FJ60 Manual
FJ62 Fender Wanted
I'm looking for a pass. side fender and possibly some other parts for a '88 FJ62. If anyone has any or knows a cheap source :D for one let me know.
TIA
Burl
cruiser@visuallink.com
adapter
Looking for adapter for Turb 400 to 4 speed t-case
Re: F engine
I have just removed the 2F engine from my 1985 FJ60. Engine has about 160,000 miles. Runs quite well with no oil consumption or smoke. Chevy 350 is being installed. I am the original orwner and the engine has been professionally maintained since new. After market goodies include Weber 38, Man-a-fre headers and Jacobs ignition. Almost new parts (lesss than 10,000 miles) include Centerforce clutch, alternator, oil cooler and water pump. A/C compressor has been converted to the "new" freon. P/S also included. Also have the stock 4 spd, transfer case, front and rear ends. The parts are located in Gaithersburg, Maryland (suburb of Washington D.C. $ 750 for engine and accessories (includeing the stock carb, maifolds and emission control parts) $750 for the trans and transfer case or $1200 for both. You pay shipping and crating. The front and rear ends (from an 1987 FJ-60) are $100 each.
Re: F engine
thanks for the reply but i found what i was looking for.i will be up and running soon.
thanks
I've got one! You can get a scan of it if you like or maybe you have parts I need!
fj40 soft top
looking for a soft top to fit 65 fj40. Also looking for a front drive shaft from a 4sp to finish my conversion. I am in so. cal. Thanks
Re: FJ40 Parts Wanted
I have what I believe are some tools and a bag. The bag isn't the best , and has a tar smear on it. I'm in WI. Let me know as they will be CHEAP!
Pete S
Old style doors
Both or one doors for early cruiser. Want to make some cutdown doors to use with soft top, don't need glass but do need handle /latch. Tops can be trashed. I'm in KC, so to not get killed on freight, would like something close, poss pick up.
Can I be any more picky???
Ed Long
:)email me direct, Thanks
Need front door window frames for '70 FJ40
Looking for both front door window frames for my '70 FJ40. These are one-piece, w/wing window. Mine are rusted beyond repair. Please let me know if anyone has such, or can direct me to a source. Thanks, Maintz
Re: Rear Swing Out Doors - Wanted
I'm in Alberta Canada how cheap for a set of 67 rear doors? Hinges and latch not needed
Re: adapter for 350
Hey, I have a bellhousing adapter to mate a 350 to the 4 speed manual.  Not sure what company it is (I'll ask my dad if you're interested - he switched to an auto tranny before I got involved with the truck).  Also have the old 4 speed if you're interested in that, too.  Send me an email if you're interested.
Travis
P.S. - I checked, and it's downey
Rear Wiper squirter needed (60)
I need the plactic insert squirter for the rear wiper washer if anyone has one they can part with?
Thanks,
Rob
passenger side steering arm
Ditching my aqualu double arm, and I need a stock one again.
I 'd swap with someone (plus cash) but I kinda need one or the other to be on my truck, So I'm looking to buy , and then sell my aqualu arm.
Bolt pattern is early disk brake...76-78 I believe...
cheers,
ryan
hello
You are selling the half doors for $40 set or each. Those also have no rust you said right. I need the rear half doors for a 71 fj40.
thanks Dave
I may be interested if you could send me some pics or them and what do you mean by minor, just surface fust or small penetrating rust.
thanks
double crank pulley- NEED IT FAST
Ok, I need a double crank pulley and a double water pump pulley. It's going on an F, if that makes any difference. Converting to power steering. I'm gonna need these parts pretty quick so if anyone out there has these, please get a hold of me.
Either reply here or email me @ sc_roush@hotmail.com
Thanks
Scott
Re: adapter for 350
i have a downey bellhousing and all necessary parts to do the conversion . i changed to an auto .
