Wanted FJ60 Manual (19 Viewers)
tnt40 said:
Not sure about the jump seats.
You should have a bracket welded to the front part of the rear fender well on the inside of your tub, that is what the rear bench seat will bolt to. I have a couple of these. Come to Minnesota and pick them up, and I will not ship them. thanks.
-Steve
OME shocks FJ80
Need some OME shocks N74 N73 :cheers: :beer:
Poser, you have the brackets or the seats? If seats, can you send a pic and how much?
2F Exhaust Piece
I need the piece that bolts to the exhaust manifold on a later 2F (like from a 60 series). My 3/80 has the exhaust that comes out and splits into 2 pipes and then back together at the cat. The later 2F's had a three bolt flange that bolted directly to the manifold. This a pic from SOR of what I need. I need the piece on the far left, and I only need 6" or so of it. If you have one let me know, I'm getting headaches riding in the 40 until I get this exhaust redone.
Thanks,
Fax
$20 plus the ride would work since it is just sitting in the spare parts pile collecting dust.
I do.
You can cut it right before that bracket, that will make it really easy to ship.
Thanks,
Fax
how about a TB? i am not sure if the 60/62 throttle bodies are interchangable... is there a 62 throttle body out there?
Comparing the pic you sent and the SOR picture it looks like the close end is the cat end. I can't see the other side well enough to tell if there is a 3 hole flange on it or not. Either way I need the Manifold end with the flange.
Thanks,
Fax
Welder
Looking for a good cheap welder, preferably one of the big three. Either a higher 120 (Like a Miller/Hobert 135) or a small 220. Please email direct, thanks! andre "at" utahbiodiesel.org
I have a set of five without hub caps, painted a bad camo by PO. No shipping. I emailed and PM'd you. Welcome to the forum.
WTB: stock seat belts for '82 FJ40
The '82 FJ40 I just bought has 4 point racing harnesses installed for the front seats. I don't like them and would like to change to the factory seat belts. I would be happy to trade the 4 point harnesses for the factory belts and any mounting brackets they use.
They are also mounted unsafely:
Little parts - clothes hanger hooks
I need a pair of these to hang a rod rack against the cieling of my 60 and would like some that match the front units. Any Help?
Thanks and merry Christmas.
Mike S
