Well the rig run now but only for a few seconds. I am not sure what to do to tune the carb to get the rig running longer so i can use a timing light to set timing. So my question is i can get the rig running but seem to run fine but starts to die like it's not getting enough fuel but when I get on the gas it sputters and back fires out the card then smokes out the carb when it's dead. So what should I do now I lost on how to tune the Rochester carb.
are you 100% positive the disty and the tdc is correct? every time I have a problem like this it always ends up being that I did not put the disty in right and not at top dead center. Last time I had this problem was with a gm hei disty that was unmarked for the plug wires. Had a friend help troubleshoot and realized that the rotor was not pointing to the right location when engine was verified as being at TDC (thumb on plug hole #1, timing mark lined up).
