- Location
- United States
This is a custom-made roll bar, made to exact specifications to fit the stock threaded holes in the interior of an FJ45. This was originally designed to support the bikini top for when the truck cab/top was removed, however, the height also allows the roll bar to remain mounted in the cab when the top is on as well. This also serves as somewhat of an additional safety feature protecting from the sides and top.
The mounting location is behind the standard cab latches. This is a simple installation/removal of three bolts on each side. Measurements include the mounting bracket that is welded on to the roll bar: 30 1/4" height, 59 6/8" length, 6 1/4" width (widest point at mounting bracket). Roll bar is 1 1/2" tubular sturdy metal. Weight is 17 lbs.
If you have an expensive headache rack that fits along the exterior, forward bedrail of your truck, then this is an extra option. If you don't have the headache rack, then this is a safety feature and a support for your bikini top.
I left the part unfinished so you can see exactly what you are bidding on. Steel is expensive and the labor for having one made is as well.
Roll bar and mounting brackets are welded together, therefore this item will be wrapped and shipped as a single unit. Dimensions for mailing will be approximately 32x62x8 and 18 lbs. Additional photos on eBay.
I have this listed on eBay as well. $100 and buyer is responsible for shipping fees. I am in Texas 77381. Thanks.
