Fj40 Rock Sliders
USA
Website
www.rutherfoto.com
So I'm trying to figure out what to do for sliders on the 40.
I like this sort of design from 4 Plus:
4+Plus FJ40 Rock Sliders W/Step
I like the stock look of these, but I'm concerned about mounting sliders on the body. With the 60, I had body mounted sliders which worked awsome 95% of the time, until I slide off a rock sideways, and with no support from the inside, it bent the whole body to a point where my doors didn't open correctly.
Any thoughts?
for the wheelin we see here in the east, I would recommend frame-mounted sliders. Once you start leaning into stuff, you will eventually comprise your bodywork with the body-mounted style. that all said, the 4+ is a nice design, you dont lose as much clearance, so you are less likely to touch. You could add some frame tie-ins to that design...
I would say it depends where you want to put that rig/who are you going to be following/how pretty do you plan on keeping it?
i agree with frame mounted sliders over body mounted.. way stronger and you can jack your truck up off them.. i think you learned your lesson with the 60.. there is a good thread somewhere in the 40 section with a lot of pics of different options.. do a quick search and check it out for some good ideas.
I vote frame mount.
North Country Cruisers makes a nice set... I'm a big fan of their patent pending kick kink at the end of their sliders, throws that booty away from the rocks.
Aye aye for the frame mount.
