Wanted Fj40 Rear heater copper lines 1980-83
WIndermere
I am looking for the copper lines that connects the front heater to the rear heater console module in the late-model Fj40's Please let me know what you have
I've got a set in storage. They were an extra set I bought for my 1980. Rear heater is in the rear bed, I would assume the lines are different for the rear heater that is in the console in 81-84? I'll pull them out this weekend & post up any pics you need to verify fitment.
The 1981-83 lines are shorter since the console is not as far back as the stand alone heater. Did the vehicle have console heater?
Here is the set I have. What measurements do you want? Hard, for me at least, to see the orientation of these out of the truck. Left ends go to firewall, long straight portion in middle runs along the tranny hump, etc.
I have 1980 BJ 40 with rear heat. Will check this weekend but I think these are missing. Will follow up Monday.
These look like they might be for a earlier 40. Hard to tell but looks like with the front line vertical looks like the back two ninety degree turns look like they raise up from the low section next to the fuel tank. 79+ the floor is flat from the front of the seats all the way. Or possible the two ninety degree turns are for going around the center console. With the front vertical should be able to tell if these nineties are running flat across the floor or raising up. If they are for the pre 79 would be interested in them. My 79 didn't have a rear heater when I bought so do not have a idea of the routing. If yours does should be easy to look at the routing.
