For Sale FJ40 for sale
Toyota FJ 40 For Sale
Asking 8,000.00
on martha’s Vineyard
Sam Low
508 693 0509
samfilm@aol.com
I need to sell this Land Cruiser because I inherited a jeep - am getting older - and don’t use it. Also because it has burned out two ignition modules and I cannot find a mechanic on Martha’s Vineyard who can ID the problem. I just don’t have time or patience for it anymore.
Pictures at fj40
1977 Toyota FJ40 Land Cruiser specs:
This Toyota FJ40 Land Cruiser has been restored by the former owner including more than $12,500 in parts and labor to date. It has a chevrolet v8 which I believe to be a 327. The truck has gone through a frame-off restoration (by last owner) in which a new aluminum tub (or body) was added to a repainted frame along with new shocks, springs, fenders, front cowl, powder-coated bumpers and roll bars, and misc. doors (which were obviously used doors). *The vehicle has been painted. It has an AM/FM/CD installed. And in 2002 it had a used transmission and transfer case installed by the current owner.
Here is a listing of the work done all verified with receipts.
·Used Toyota purchased 12.01.97 – $3,000.00
· BFG All Terrain tires – 10-26-98 – $696.63
· Front and rear shocks, tie rod ends, steering knuckles – 7/19 – $721.14
· Recond radiator 5/14/01 $320.25
· New block heater and misc. – 12/06/00 – $196.10
· New clutch and throwout bearing – 12.13.00
927.84Distributor repair – $177.67 - 3.6.00
·· Replace Fuel pump, radiator hoses, and fuel filters –$137.00 - 8/265/01
·Install Stereo AM/FM/CD – $505.14 – 6.8.99
· Install manifold and brake master cylinder – 1.26.99 – $312.65
· Fabricate and install custom exhaust and side nerf bars – 4.30.99 – $346.93
· Install new camshaft and timing gears – 3.18.98 – $954.91
· Misc. parts from Manafre – $489.19 – 3.31.99
· Misc. Parts from Front Range Cruisers – $108.79 – 12.29.97
· otal frame off body restoration – new aluminum tub (body) sandblast, rhino lining, paint and primer body, new fenders, paint frame, dash cap, rebuilt xfr case, powder coat bumpers, grill, roll bar, 2 rear doors, 1 front door, repair radiator and fan shroud, reverse shackle installed, miscellaneous cleanup of rig – $6375.68 – 10.28.98
· Paint entire truck – 5.8.00 – $570.33
· Misc. Parts – classic cruisers – $320.25 – 5.14.01
· Motor oil and lube – $104.28 – 5.13.02
· New Distributor cap, thermostat (190 degrees) tune – 260.24 – replace distributor and wires – 8.24.01 – $600.00 - 6.20.02
· Replaced water pump – clamps for mufflers – timing adjust – 5.23.02 – $185.90
· Install used transmission, reset transfer case gear lever, and fix parking brake –-6.5.02 – $1122.73
· Install new pipe to left header of v8 and new muffler c. 2008 – c. 800.00.
cant tell what color that is- mustard? more pics to wbryancody at msn dot com. esp of underside and motor. I know it has been restored but how has the last 10years of sea fog treated it as far as rust etc?
Thanks
