- Joined
- Oct 21, 2010
- Threads
- 20
- Messages
- 372
- Location
- Carson Valley, Nevada
- Website
- troutadventures.org
So, as I noted in the May run thread, a broke off a stock welded on frame nut. I figured out how this happened. The after-market skid is designed to be mounted flush across the main crossbar. But only the center portion of the cross bar is flat. The weld on nuts are on the outer portion. So this leaves a decent sized gap between the cross bar and the flat skid.
Now, apply lots of pressure to the unsupported portion of the skid. The skid binds in, the bolt becomes exposed (it's partially recessed), and then it can take a direct hit. It doesn't take much of this snap the weld. Actually, it took one trip through Eldorado Canyon.
One way or another, the gap must be eliminated. One minor complication is that the bolt sits in a counter-sunk washer in a 1" whole in the skid... and if you have full skids like me, thru a 1" whole in the next skid (which is layer under the engine skid). So the build up needs to large enough area to provide solid contact to the skids its supporting.
Anyways... nothing a person with decent fab skills cannot cure...
Also, as I noted in May run thread, I rounded off bolts holding the cat protector tubes in place. The inner bolts are especially exposed. The stock solution is little protection tabs, pretty worthless. For this skid kit, the solution is to recess the bolts, with in hunk of bar stock.
This might be enough protection... guess I'd like it better if the edges of that hunk of bar stock where beveled. But I guess they will get rounded off on the trail soon enough. Just hope the right angle edge doesn't catch on rock.
