FJ Old Man Emu Install LIVE...NOW...Watch
Here we go...now the picture is here...
Gilead said:
Tires and in the air...
VERY Cool!! :cool:
Now where can I buy that kit?
Thanks for the Uber Install Post.
Now that it's finished I guess I should get back to work. :rolleyes:
Shawn
Okay, it is now on the ground. Here is the deal at this point. As you can see the front is "diving" Big Time. This is because we have the OME 893 and this is a non-USA coil that is specifically designed for low height Prado's. We are now putting the Cruiser back in the air and swapping out the coils for a set of OME 895's. We have been on the line with Tim the Tech guy at ARB who knows his stuff inside-and-out about installs. Watch as we continue with the process....
Tedd, let's hope you meant OME884's on the front...
The OME895's should have been correct for the rear.
FusionCruiser said:
VERY Cool!! :cool:
Shawn
The suspension still is available!!
See further down!!
As we wait here...We took this FJ out on two different occasions in Maine and New Hampshire to wheel it before we did the OME install. We did not kill the thing, but did get into a number of off-camber situations, mud, and inclines. Over all we thought it went well. Yes, we know about the IFS vs. sraight axle "beef."
the truck looks alot better. When will the ome kit be available?
Sorry for the delay...business....:) Okay, the front system is in ands it sits much much MUCH nicer. Note pictures. Here are the number now...LH- 32", RH 32 1/4". We ran the Trim Pack on the LH side. None nthe RH.
wasn't it a shade taller on the DS prior to the lift? "suspect" Toy does that so the DS levels once the driver's dead ass is installed....
curious ;)
