Performance Brake Kits, Rotors and Pads are now available for the FJ Cruiser.
This brake kit is a performance, stock replacement for your Land Cruiser. Premium brake pads included. Rotors and brake pads are direct replacement, require no alterations or vehicle modification.
Both Rotors and Brake Pads are the very best available. Improved braking Performance and longer brake pad and rotor life can be expected. OEM Replacement Rotors available too.
Not sure about drilled and slotted rotors? Consider that 90% or more of your driving is on the road where you need superior braking performance most.
Increased dissipation of water, dust and road grime from the contact area of your braking system.
Improved integrity of the pad and rotor surface, through deglazing of the contact area.
Directional slotting surface also combats “out-gassing” which is caused by gas from the brake pad bonding agent forming a cushion between your pad and rotor and thereby reducing pad “bite”.
BOTH OE (Original Equipment) and Drilled and Slotted Rotors Available.
Visit us at www.jonesysoffroad.com
Contact us at info@jonesys.com
