- Joined
- Jun 5, 2005
- Messages
- 82
Wheels: 17" 6 lug. Steel rims 17x 9.0 J.J. 2.50" back spacing Made in U.S.A. 6 x139.7m (6 x 5.5"), Fits Toyota Land Cruisers: FJ40, FJ55 and Fj60, Toyota 4x4 pickups and 4Runners (make sure to check if a 2.5" backspacing will work with your rig. Tried these on a Land Cruiser '80 series with J springs and they rubbed ('80 series backspacing is 4.5")). Powertank Monster Valves installed on 4 of the tires ($170 value). Also has the standard valve stem. These were custom made with the 2.5" backspacing so good luck finding an off-the-shelf 17" rim with 2.5" backspacing. New wheels with 2.5" backspacing and the Monster valves installed would probably cost you $800~$1,000.
Tires: Toyo Open Country M/T Mud Terrain Radial Tire - LT285/75R17 121/118P Load Rating: E (10 ply). Tire size in inches: 33.8". Used but like new with whiskers still on the sidewalls.
5 tires new will run you about $1,800.
These were just recently balanced so I will not separate them.
Monster Valves are an over-sized secondary valve stem for super fast tire inflation and deflation (1 minute or less). Inflation requires a Powertank and Monster value air chuck.
$2,000 or best offer. Located in Redwood City, CA
