Back to tech, as you can see my plan is to run portal axles which will give a 7" lift approx. I would hope from what I've seen so far to run no lift (body or suspension) and cut the body. Do you think if I run a 1" to 2" forward and rear stretch (i.e move the front axle forward 2" and the rear axle backwards 2") I'd be causing myself massive headaches? Then I could just tub out the wheel wells and cut the fenders for clearance.
I want to run a full body and street drive the thing as in 'support truck' mode it will have to be covering 150+ miles a day of paved and un-paved roads. To do that I've got to keep it low, but I don't mind chopping it about. I'd hope to run standard hieght suspension and standard up travel, then use the changes in links, joints and shocks to give increased drop travel. That way I can control roll and drop on the street with sway bars that can be dis-connected for off road use.
Thanks for your help.
Oh, quick edit to say the reason I'm looking at 42"s is that the Unimog axles come with a 7.68:1 ratio and are only rated to 50 mph. By fitting 42"s instead of the standard 38"s it gives me a usefull extra 5 mph before I risk overheating the portal boxes. I hope with a disc conversion and some cooling aids to be able to run it at 60 mph.
I clearly missed the part about running mog axles, but it still doesn't change a lot of what I have said. just move the rear axle back a few inches and you'll be fine (thanks to the artic tech 12mm is definitely clear you of the 42" tire issue.
One thing to point out is that with MOG axles if they are anything like hummer axles (I think they are similar in style). Because you get all that ground clearance and natural lift. it means you diff sits much higher, which means that you can afford less uptravel on your axles. Ken Hanna (hannaquality) is running H1 axles and is limited to 6" up on the truck and you may want more. You can always cut out the back floor of the truck and raise it up but in the front you'll be hitting engine. I'd make sure that all your ride height and uptravel math works out nicely. I don't think you need the forward stretch since you don't mind cutting away and if I recall correctly, mog axles are wider than stock 80 which will help with turning radius clearance.
I would INsist on adding hydro assist to your setup as well and the proper steering and tranny cooling upgrades. 7.68gearing is INSANE (in a good way). with 40's and 5.29s all my gauges and response are just like stock. I'm not familiar with the axle heating issues that you're referring to. I'm sure some Royal Purple gear oil will help greatly with that. Post up some pics or start a build thread once you get started. let me know if I can help in any other way.
