- Location
- United States
First gen Toyota trucks and 85 4Runner! TX
I have several trucks i need to sell. Houston (conroe) TX
1982 (blue)Truck has some rust, frame is in good shape. The truck needs a engine, it is complete otherwise. The front axle has an ARB airlocker. Interior is complete and has aftermarket bucket seats. $1300 clear title
I have a 22r that i just finished building that can go with the truck for an extra $1200. Crank was turned and polished with correct bearings professionally installed, head has an rv cam with dual valve springs and dual timing chain. Valve cover and many other parts were powder coated. (will only sell if the truck sells)
1981 SR5 5 speed (black), a/c etc... Truck is not running currently as the manifold was removed. AC was working when parked. Tree fell on the pass fender/hood and cracked the manifold. $1200 clear title
1983 SR5 long bed(biege/spray paint), truck has factory sunroof and bucket seats, tilt steering etc... will start and run, was told it needed a clutch. front calipers are missing also. no title $1700
85 4runner (gray)for sale, the motor has been removed and needs to be machined and assembled, everything is there all you need is to rebuild the block and bolt in. The body is in good shape with no damage and no rust, the paint is a little faded. The interior is decent with the original SR5 seats, power windows, tilt gauge etc...
87 4runner (red) 3' rancho lift (new) with rs5000 shocks, auto trans is shot but the engine runs perfect, was going to use the engine in the 85 and swap the rear end etc..
$3200 for the pair (only sell them together or ill build them.
http://picasaweb.google.com/speedfetish/TrucksAnd4Runner#
robert
832-724-8395
robert
832-724-8395
