Fall Gathering Swap Meet
Need to clean out and get ready for winter
3) h42 w/ 4speed transfer cases $100
left front fj62 fender-perfect shape $50
fj40 axles 4.11 ratio $300 pair(fine spline)
fj40 axles 3.70 ratio $300 pair(fine spline)
fj62 front axle $250
perfect fj62 dark grey dash $75
2)white fiberglass tops
2f oilpan
2f intake/exhaust manifold
62 radiator
62 power steering pump
Have a Saginaw box and the mounting plate for a 40 conversion. $60
Roller fairlead, surface rust. $15
Front heater parts Free
4Runner calipers $15
40 series rear drum parts, drums and cylinders free.
Will have parts for the mini conversion available in the spring to include; mini box $30,
pedestal $50
Lane
PM'D you on the fairlead
condition of fiberglass tops?
one good fiberglass good, raingutters dented or split from gf in 3 places
one perfect(from Arizona) with the exception of a 16"x16" vent cut in the back
Also
4) 31x10.5 BFG AT on nice white spoke wheels 95% tread $350
4) 295-75-15 hercules snow tires on 60 rims with a little rust(tires 90%) $175
4) nearly bald summers on 60 rims with a little rust $65
5) 60 rims a little rust $100
75 hardtop, perfect fiberglass and gutters, a little rust on bottom corners
and finally...
my 2F in my red toyota. It was rebuilt by Stew about 3-4 years ago. I guess that it has less than 5000 miles on it. $700
and finally...
To be replaced by what? : )
Do yourself the favor and find a block with the extra 45 cubes. A 350 has so many more options than the 305 and the TPI set-up should bolt right up and run fine. 305's are good for boat anchors.
You have the motor already?
I have one out of a 86 iroc with only 600 miles on it. It was from a stolen car that was to be put in a street rod that sat under a guys bench for 20 years. I will change the cam in it and warm it up
would anyone be able to bring a bib from the FG down to MA for me?
I go to school in Worcester but this weekend I have a singing gig in NYC so I won't be able to make it to the FG
you can PM me or write here.. let me know
Thanks!
Ant
Okay here's what I got. I probably won't drag it down there unless I catch some interest here.
4spd with tcase (non split case) $75 I also have the bell housing and flywheel that came off a F motor I will include
PTO box $200
PTO winch w/ one broken mounting point $80
SOR tail light protectors. $35
(4)6 lug Nissan wheels chrome wheels should fit a toyota $40
2f intake $50
FJ60 hood very little rust $25
2f Propane set up still needs to be removed from the truck $275
Fj60 rear axle $75
Probably have other stuff that I will add later
swap meet time?
does anyone know or want to set up a time for a swap meet?
i am thinking before the barbeque, if there is time, or after the half day wheeling on sunday?
I was gonna leave my stuff in front of my tent for the full 3 days.
