Bought my 2000 LC used at 70000 mi. Sighed when at 73000 miles, antifreeze began leaking from the cylinder head gasket on the left side of the motor. no idea what set it off, but probably had something to do with the first owner. So It was replaced and things seem ok now. They also found a bad exhaust manifold gasket too. I changed the plugs, which i'll try to post a picture of, but all of them had a rust brown coloration to them.
Do LC's have common gasket failure problems?
I wouldn't know, but The toyota dealer that did the work talked like gasket failure was a fairly big thing to happen to the motor, but they didn't offer any suggestion for further preventative work, tests, etc. replaced parts etc.
If indeed what happened was "big", what maintence/test should be done to make sure everything is ok and up to speed. e.g. water pump replacement?
Pequiod.
Pequiod.
