I am about to order some custom wheel spacers. In the options, I can either order hub centric only or hub and wheel centric spacers.
I am trying to weigh the pros and cons to each and I am looking for input.
Also, does the center bore of the different oem wheels change or does it stay the same? I need to give them this number for the spacer. I am currently running the stock oem 16" wheel. I would like to in the future go to an 18" oem LC/LX/Tundra wheel. Is the center bore of the wheel going to change or will it be the same?
Does any one know what the stock oem center bore dimension is? (I know I can measure mine, But I would also appreciate it if some one can post their 18" or if some one has a cut sheet with all the OEM wheel styles and specs...
Thanks!
Thanks!
