So I am quickly approaching the end of my 3yr/36k warranty on my Tundra. In this time I have had the following warranty work done:
Gas pedal recall (probably bogus)
Front Diff Rebuild
Serp belt and tensioner
rear cab mounts replaced
front trim piece replaced
Now I already feel that this truck isn't quite the quality I was expecting from Toyota.
I know that Kieran's (Vtcruiser60) truck is the same truck as mine and only a month off in production date has had an issue with the air injection pumps going. Which can cost as much as $4000 if out of warranty.
Anyway I an still get a Toyota Factory Platinum extended warranty if I do it before the 3yr/36k is up. Originally at the dealer they wanted like $2000 for it. No chance at that cost but now I find that there are some dealers which will sell it for a lot less (yes I it is the actual Toyota factory backed warranty). I would like to get the 8yr/100k and I had heard it can for a littke over than $1000.
What are peoples thoughts? Should I pull the trigger now or roll the dice.
Here is the link to the coverage:
http://www.toyotafinancial.com/cons...epository/tfs/en_US/document/TFS_Platinum.pdf
Front Diff Rebuild
