Just bought a 76 FJ55 with a factory disk brake front end. I want to swap out the entire axle for my drum brakes setup i currently have on my 73. Who has done this? What was your process?
I noticed the brake booster for the Disk front end is considerably larger that the drum booster. I have a completely stock F motor with the factory carb. Linkage for the carb looks to be in the way of the disk brake booster. What are my options for fitting the new booster in? Rochester conversion? Is there another booster off another car that will allow me to retain my factory carb? Any help would be most appreciated.
Is there any changes that need to be made to the drivelines? I heard the flanges on the diff for the disk brake front end are different from the drum front end. Can i pull the flange from my drum front end and install it on my disk front end?
Any advice will be most appreciated.
Thanks
Thanks
