Hi all,
I have an Aussie spec 2005 hzj105 standard.
This means it is 1hz diesel powered, solid axle front and has the part time/manually select 2hi-4hi-n-4lo transfer with manual locking hubs.
Mine also has front and rear factory diff locks.
I've just been thru the forums figuring out why I couldn't select N or 4lo and have since discovered the two arm select method - so I can get into 4-lo.
I now also have operational front and rear lockers as I replaced the 4lo select switch - this was preventing the lockers from engaging.
My question is: I often need to engage the rear locker in 4-hi or even 2hi (don't lock in hubs) can I modify the switch which wasn't working to be "normally closed"? This would then send the signal to the lockers allowing them to be switched at any time wouldn't it?
I do not have ABS, and it is a manual so I don't have the overdrive lock out issue. Are there any other problems I may cause?
Secondly, can I wire in a switch to disconnect the rear locker somehow? I need to use front locker at times, without the rear - the factory switch does not give me that option....
Any advice appreciated!
