Face separation cable
Fallon
I need a face separation cable for an Icom ic-2710h, does anyone know of someone that might have one. they have been discontinued by the manufacturer and are not available even through icom.
thanks
John
thanks
John
Did a couple of web searches, looks like the OPC-600 and OPC-601 cables were replaced with the OPC-600R and OPC-601R cables, respectively. Both of these cables seem to be available.
IC-OPC600R - Icom - HamCity / Ham Radio Equipment - HamCity / Ham Radio Equipment
Hamcity seems to have the OPC 600R for $45, and lists it as being compatible with the IC-207H.
-- Kurt
Opc-438 & opc-439
The 600 series cables according to the manufacturer are not the same. Above are the cable part # from the manuel.
ic-2710h is different than the model you are mentioning.
I just went to hamcity and took a look, it indicated that it will work, I will check into this and get back with you, thanks for the lead.
I'd encourage you to pick up a phone and call them, they are very knowledgeable and a call may help you get the right thing the first time.
that will be the plan on friday, thanks for the heads up.
All is good, from Ham City, the IC-OPC600R is compatible to my radio and what I want to do. Thanks to all for your input and guidance.
