Extra fane for extreme hot climates
Guys is there a way to add extra fan to reduce the temperature?
It reaches 130 F where I live and the other day, I was stuck in traffic and AC stopped working cuz of the temperature. Thankfully it worked once the car had cooled down little bit.
I had installed small fan for compressor in the front which helps with AC.
Temperature is working fine. Coolant topped off and fan works properly.
Just need extra one when to get stuck in traffic with this HEAT
Any suggestion?
Sounds like a thermostat issue or even symptoms of a head gasket. I have a GCC spec LC here in Saudi and it never does that and we go over 130F and take our cars into the desert.
Thanks lifarms, not at all. i am in saudi as well but that happened once during stopped traffic for 30 mins. car is 2007 lx470.
Currently in Riyadh.
Well it could be thermostat, seen some red splash around that area
Any suggestion?
sounds stupid... but have you ever washed / cleaned your radiator and ac coil the cooling fins can get very clogged and limit the air flowing through... sand/dust ect just like the cooling fins on your home a/c unit... you need as much air flow as you can get
i usually clean Radi coils with pressurized water, definitely not clogged. plus the air flowing here just like ' Hair drier on HOT" :D
