Exterior Light Rough In Wiring - Question
I'm at the point where I'm roughing in wiring on the new garage. For exterior lights - wall mount - what is the preferred choice on box or not? I seem to see either the option of installing a typical round box in the wall like you might on an interior wall, or just running the wire through a hole and leaving a pig tail outside. Then installing the exterior light right to the wall with no box.
Any suggestions on your preferred option and why? Is there some other method that I should be going with?
FWIW my siding is hardie vertical siding over OSB so it will be easy either way. Just cutting a big hole with a box, or little hole with some wire sticking out.
If the light is 6 lbs or less then a single gang box is ok. I preffer a 3/0 box for strength though.
