Hi All,
Hoping someone can check my troubleshooting method and confirm diagnosis. And also offer options for next steps.
85 FJ60 desmogged.
Symptom, have a loss of power over last year, lots of oily water out exhaust. Also blowby symptoms, like smoke out of oil cap, excess oil in air cleaner.
Did compression check, # 2 is at 30psi, others are OK ranging from 130-150.
Wet test on #2 did not make a change.
Suspected valve.
Pulled valve cover, verified that when valves were supposed to be closed there was no tension on the rocker/ and a gap. Valves appeared to be up and closed.
Loosened both valve adjustments to be sure both are closed.
Put 100 psi air pressure into #2 cylinder and can hear air at exhaust pipe. Not a big whoosh, just a constant hiss.
No noise at Carb and no bubbles in radiator.
1st question is if this definitely a leaking exhaust valve, or could it be another cause?
2nd, is it possible to possible to remedy w/o pulling the head? Like seafoam treatment etc.
Thanks for any relies.
Dave
85 FJ60 desmogged.
Suspected valve.
Dave
