Exhaust Man and Overheating
Nairobi, Kenya
Recently my HJ60 (2H engine) has started to run hot, not overheating but running at about the 3/4 mark. This started awhile back and only happened when at highway speeds and in 4th-5th gear. Lately it has begun to do it all the time, the temp climbs quickly to 3/4 and then stays there.
I have tried flushing the engine twice, though after doing more searches on this site, I have realized that I may not have properly burped the engine. I have also put in a new T-stat 82 degrees (there was none in before and no probs). The t-stat doesn't seem to want to open for awhile, but several posts seem to suggest that this may be common with a new t-stat, so I am not yet blaming that.
I recently noticed the engine is drinking quite a bit of oil as well and after giving the engine its first good cleaning in a long time noticed that it seems to be leaking at the rear most exhaust manifold port. I also noticed that the engine cools quite quickly once the engine has been turned off. Could this exhaust leak be the cause of the higher than normal temps? Also does anyone have any tips/ suggestions on replacing the exhaust manifold gasket? The manifold seems a bit warped so I thought I would take it to the machine shop to have it skimmed to size- any tips?
John
I know how to do it on a 2F, but i don't know on a 2H. I don't want to give you bad advice.
:beer:
