DON'T try and do this cheep, if money is an issue than save your cash until you can afford a good QUILTY rebuild. I don't care what engine you are rebuilding it will cost at least $1000.00. Only a machine shop can bore blocks and turn cranks. Tear down the engine in the correct way, take the block, crank, rods and head to a good QUILTY machine shop and tell them to do want is necessary in regards to machine work. The machine shop will tell you what they over bored the cylinders to and turned the crank to, then order your parts based on the new bore size and crank size, then take your new pistons to the machine as they will hone the cylinders to the pistons as well as size the connecting rods and fit the pistons to the rods. The head is another story, some including me will recommend a new head, the reason is that they are prone to warping and cracking, a brand new head can be purchased from engine builder with a complete valve train for a reasonable price, a bit mor gets you one with larger valves and ports. I just rebuilt my 22RE using engine builder parts including his big valve head with RV cam, it is worth the extra cash. Machine work cost me about $400.00 plus parts. I can not stress enough how important it is to do this correct, if you don't you will be plagued with problems. I am a fan of DIY, I know what parts were used and that the job was done correctly, plus my labor, remove and install, is free. Oh and you might as well remove the injectors and have them cleaned too. Good luck!
Sent from my iPhone using IH8MUD
