I am finally getting around to installing the 1HZ in place of the 1PZ (due to misfortune, not planning). The result has been the transmission being moved rearward about 1.5 inches. My question, which you may be able to answer, is this: Is the Bellhousing or the Transfer case adapter of the R151 that was bolted onto the 1PZ shorter than the bellhousing or transfer case adapter of a R151 bolted onto a 1HZ?
Thanks.
Thanks.
