Went off-roading a few weeks back and the engine hasn’t been running well since. Engine stumbles pretty bad up around 2000 rpms and idles slightly rough. Seems like a got into some puddles high enough that the fan sprayed the whole engine bay with silty water. I pulled the plugs and did a compression test. The results are in the photos as well as the pics of the Spark plugs. Spark plugs 1-5 had white build up on them, sp6 was more normal looking but was missing some metal off the very bottom. Also got a cyl6 misfire code the same day as off-roading but after clearing it it hasn’t thrown that same code again. I think this means I’m running hot in general, but what can I do to fix it?
