engine noise
Try checking the where the EGR cooler tube connects to the bottm of the exhaust manifold. If the gaskets gone it can make what sounds like a clicking noise when reving or accelerating.
Good Luck.
ERICH
solid lifters/valve tapping(make noise :) )... loose spark plug wire will click...but its prob just valve tapping..
You should also check the valve clearance if they havn't been adjusted in 20k miles. Too much clearance can be a bit noisy and reduces power.
